Can you buy a license for UNISIM libraries to use in an ASIC
Hi all...
Let's see who knows the answer to this:  We are trying to fab an ASIC based on a design done in Xilinx.  The design is structural and uses the UNISIM libraries.  Now, is it possible to pay for the right to use the UNISIM libraries in our ASIC?
Much thanks to whomever knows the answer.
Historian
Historian
Re: Can you buy a license for UNISIM libraries to use in an ASIC
@cbuchendu wrote:
Hi all...
The unisim libraries are, as one might guess from the name, behavioral simulation models. The source code for these models is readily available (it's in the Xilinx tools installation tree), and it is very much not synthesizable at all.
The models are provided so the engineer can simulate a design which uses the various Xilinx primitives and blocks (such as the DCMs, the DDR I/O, the input and output serializers, etc etc).
You need to use the unisim library in your source code when you synthesize using those various primitives; the package you used includes the necessary component declarations. You use it for simulation because it's the interface to the behavioral models.
So, the short story is: there's no "license" per se for those primitives because all that the library does is provide a hook into something that's a hardware feature. If your design depends on a Xilinx DCM, then, you'll have to see if your ASIC fab has something similar in their IP list, and you'll probably have to rework your code to take advantage of it.
how about someone pointing me to the license agreement for the UNISIM libraries; I can't seem to find them.
This is the license to which you agreed when you installed the Xilinx software which contains the verilog/src/unisims directory:
http://www.xilinx.com/support/documentation/sw_manuals/end-user-license-agreement.txt
Historian
Historian
@cbuchendu wrote:
Hi all...
