Cannot find <std_logic_1164> in library <ieee>.
when i synthesize my design for vertes series, I'm able to synthesize. But the same design if I do synthesis for Spartan 6 series, I'm getting below errors:
Cannot find <std_logic_1164> in library <ieee>. Please ensure that the library was compiled, and that a library and a use clause are present in the VHDL file.
ERROR:HDLCompiler:1084 - "Unknown" Line 0: Registering Dependencies Error: The primary unit 'standard' could not be found during restore
ERROR:HDLCompiler:1051 - "Unknown" Line 0: unisim.vcomponents failed to restore
ERROR:HDLCompiler:104 - "D:\designs\Tri_ETH_MAC\sync_block.vhd" Line 68: Cannot find <vcomponents> in library <unisim>. Please ensure that the library was compiled, and that a library and a use clause are present in the VHDL file.
ERROR:HDLCompiler:104 - "D:\designs\Tri_ETH_MAC\sync_block.vhd" Line 70: Cannot find <standard> in library <std>. Please ensure that the library was compiled, and that a library and a use clause are present in the VHDL file.
ERROR:HDLCompiler:69 - "D:\designs\Tri_ETH_MAC\sync_block.vhd" Line 72: <bit_vector> is not declared.
When I re-install Xilinx ISE it starts working for 1 or 2 days. I'm using free versions of Xilinx tool and 30 days evaluation licence key...
Please help me in resolving this issue.
Have you declared the library
library IEEE;
use IEEE.STD_LOGIC_1164.ALL; at  the beginning of the code?
-Pratham
