nolefran
Checksum old method calculation for IMPACT
Hello everybody,
when I use Jtag Programmer  the CPLD XC9500 (.jed)  I obtain the checsum correctly (old method calculation) but when I use Impact Xlinx the checksum is different.
Can I set the software Impact in old method calculation?
If yes, how I can change It.
Thanks in advance.
rho88
nolefran
I tried this solution (see file attach) but the sw Impact Xilinx calculates the same checksum before modification.
Can someone help me?
rcingham
Did you log off and on again after setting/changing the environmental variable?
"If it don't work in simulation, it won't work on the board."
nolefran
yes, I restart the pc but it's the same
:smileysad:
rcingham
The AR is from late 2007, so it is quite possible that iMPACT is differently broken now!
rho88
Actually, that AR is so old it's pre-impact!  They are referring to the JTAG Programmer in that AR not iMPACT.  If there is a way to do this it's hidden in the software, so your best bet may be asking support if there is some other hidden environment variable to use a different checksum calculation.
