allfor
Clock skew balance issue
Dear :
     In my design, there is a IP which process data from different IO interface. Therefore I have to varify the function with clock domain switching.
As I know, all global clock element such as BUFG and BUFGUX come from BUFGCTRL primitive which has blance tree to FFs. But how the delay behavior between BUFGCTRLs ?
Is the dealy between BUFGCTRL is the same in FPGA silicon or in the same region (top / bottom) ?
If there is a regular delay between BUFGCTRLs, I will try to insert extra BUFG element to balance clock skew manually.
