arcpage
Compiler Error
Hello everyone,
I try to co simulate a design on a ML605, and this error appears :
FATAL_ERROR:Simulator:CompilerAssert.h:40:1.29 - Internal Compiler Error in file ../src/VhdlConcStmt.cpp at line 1574   Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
FATAL_ERROR:SimuUnsupported type : datacomplex for output: xout0
I don't understand what I did wrong...
Can anyone help please ?
arcpage
I found the solution to the problem.
My design use a package in which user types are declared.
The hardware co simulation isn't able to parse correctly my design.
I had to make a wrapper in order to peel the user types in standard types in the port of the co-simulated instance.
Now it works.
drjohnsmith
did you open a web case like it suggests ?
arcpage
Thanks for replying !
I'm not allowed to send the project.
I can't use the WebCase to solve the problem but I think it's internal to the compiler.
I checked the package where the type datacomplex is declared, and the syntax is correctly written.
rcingham
It might be correct accrding to the VHDL LRM, but is it a construct that XST suports?
BTW, which version of ISE, and what devices (ISE has version specific parsers)?
I can pretty much guarantee that if you can't post the code that causes it to barf, you won't get a useful answer...
"If it don't work in simulation, it won't work on the board."
arcpage
I use ISE 13.1 with VHDL Source Analysis Standard VHDL-200X on a ML605. XST must support this package.
rcingham
Why must it?
drjohnsmith
any synth supports a sub set of what is possible,
I've worked for many secure places, where we can't give out code,
   but
what I have always ben able to do if I have had a librarys problem,
   is reproduce it in a none related new project
doing this, a) says it is the libraries your calling up
    b) gives a smaller project that you can release to supportdesk.
and, I should say, it does not seem to me like a library problem,
   more like none optimum coding.
I have seen this sort of thing
    but when people are using none fpga IP, or graphic coding , like matlab / simulink.
mcgett
This isn't a "normal" ERROR message.  There is something in your code that the iSim simulator can't handle correctly and is generating software source code FATAL_ERROR.  If you can't provide the source files to official Xilinx support then there is little chance for anyone to find out what went wrong and provide a work around and an eventually software fix for this issue.
There is one small glimmer of hope in the second message "Unsupported type: datacomplex for output xout0".   Since only you have access to your source code and know what "xout0" is and what "datacomplex" is you are the only one that can attempt to debug this.
arcpage
Now it works.
