Visitor rvlganesh
Conversion of .m file to .vhdl file OR .vhdl file from .c
           I am implementing the code for image comparison in C and MATLAB.Now i want to know the process to create .vhdl file from .m file (or) .vhdl file from .c file on xilinx or is there any opensources available for this conversion and also is all .m files can be converted to .hdl files or is there any limitations.Please,let me know as early as possible.
Ganesh.
Mentor awillen
Mentor
Re: Conversion of .m file to .vhdl file OR .vhdl file from .c
I take it you've never written anything in VHDL before, is that correct?
Adrian
Please google your question before asking it.
If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
Visitor rvlganesh
Respected Adrian,
     Thanks for your reply.Actually my project is comparison of fingerprint images for ATM accessing.In my project i want to do comparison of two images using MATLAB and then convert that .m file to .vhdl file from that i want to generate .bit file to run on FPGA or .hex file to run on ARM .I enquired about the conversion possibilities,someone is saying that it is possible by using mbox tool in xilinx but some one are saying that it is confined to some functions in matlab.so,that i want to confirm about its possibilities of conversion.Please, let me know as early as possible.I am also attaching my project base paper.
Thanks&Regards,
R.V.L.Ganesh
Teacher eteam00
Ganesh,
On behalf of my twin brother Adrian (with whom I was separated at birth), please consider answering Adrian's question:
- Bob Elkind
SIGNATURE:
Summary:
Advisor eilert
Advisor
Hi Ganesh,
there are two ways that lead from Matlab to FPGAs.
One is the HDL-Coder Toolbox. The other one is Xilinx System Generator.
Both have their pros and cons and yes, there are limitations.
You can't just convert any code. It has to comply with some strict rules and restrictions.
Similar things apply for C-Synthesis tools.
Which is no wonder, when you take in account that even VHDL itself can only use a subset of itself for synthesis.
The point is that you are going to design hardware, wich differs greatly from software.
If you have an algorithm working nicely as software, there is a good chance that an identical approach of a hardware implementation fails badly.
And while all of these tools may be quite nice for algorithmic stuff (if you know how to handle them) they behave clumsy when you are going to design the interfaces to the outer world of the FPGA.
Have a nice synthesis
   Eilert
Visitor rvlganesh
Hi Eilert,
     Thanks for your support.I will go through the process and if any queries i will confirm with you.If you dont mind can i get  the screen shots of the conversion process.
Thanks&Regards,
R.V.L.Ganesh
Advisor eilert
Advisor
Hi Ganesh,
If further questions on specific details come up, just post them or write me a message.
About the screenshots: Well, there's nothing much to see on the screen but progress bars.
Also I only have access to Xilinx sysgen. The other tools, I know about but don't have them installed.
  Eilert
Visitor rvlganesh
Hi Eilert,
         Thanks for spending your valuable time.I will go through the process.
Thanks&Regards,
R.V.L.Ganesh
Historian
Historian
@rvlganesh wrote:
Hi Eilert,
Thanks&Regards,
R.V.L.Ganesh
Since you refuse to answers Adrian's question, we can only assume that you've never done anything at all with VHDL or FPGAs.
Good luck. You'll need it.
Newbie smanohar
Hi Eilert sir,
my M.tech project is Face recognition on virtex5, i want help for the my algorithm part, My algorithm is Haar classifier (viola jones algorithm). i dont know how to start the my algorithm part.
then my project is the video processing based, so i dont know how to give pixel value in Input, that is i dont know how to convert the video file into TXT file.
then how to give pixel value's in RAM ?
Then I was finished my simulation part in MATLAB, so how to convert the .m file to .v file(like verilog file) ?
there r two way to convert the HDL file
1)  Simulink HDL coder
2)  AccelDSP Synthesis Tool or ACCELDSP Software tool
I dont know about ACCELDSP software, so plz give me the procedure for that software
help me
Thank you,
by,
Mano.H
Newbie smanohar
Sir, My project is Face recognition on FPGA virtex% kit,
I dont know about ACCELDSP software, so plz give me the procedure for that software..
thank you
Visitor pankajp12
Hi guys, I am working on Video Compression , I done compression in MATLAB. Now i want to convert that .m file to hdl file or .c file. How it is possible.let me know
