matrix39
Create an instantiate only file of my prop
Can I create a file in ise of my project that can only be instantiated or used as a schematic symbol, because I don't want to give the source code away just a factional file
vemulad
You can use netlist file (.ngc) of the submodule which can be instantiated in top module using black boxing technique.
Deepika.
Deepika.
vemulad
Deepika.
Deepika.
