anilsutej
DDR2 interface with Artix-7
We are facing the problem in testing the DDR2 with Xilinx Memory controller.
We are not getiing init_calib_done. On Debug it was observed that VREF is jumping to 1.5v as soon as controller is trying to access the DDR2(Calibration Phase).
In normal condition(After Power Up) VREF is 0.9v. Please suggest on how to solve the issue.
FPGA : XC7A100T-1CSG324
DDR2: MT47H64M16NF-25EL
Anil Sutej
vsrunga
Chek if vrefs pins are by mistake used in your XDC,  also please start with pdf attached to below AR and see if you have followed all the design guideliness
http://www.xilinx.com/support/answers/43879.html
Vanitha
anilsutej
Hello Vanitha,
Thank you for the reply.
We have cross verified the xdc and found no vref pins in xdc.
If required we will send you the project and schematic.
Anil Sutej
mcgett
M12 should be connected to the DDR_VREF net on the board. This is not the reason for the voltage to go o 1.5V, but the system will a higher amout of errors with both VREF pins correctly connected.
