Anonymous
Not applicable
DDR2 simulate problem
i have generated a ddr2 ip with MIG 3.3.but i can not  simulate it with the following error(modelsim SE 6.5e):
# ** Error: ../sim/sim_tb_top.vhd(578): (vcom-1136) Unknown identifier "j".
# ** Error: ../sim/sim_tb_top.vhd(578): Bad expression in left operand of infix expression "+".
# ** Error: ../sim/sim_tb_top.vhd(578): Actual (indexed name) for formal "bcs" is not a static signal name.
# ** Error: ../sim/sim_tb_top.vhd(662): (vcom-1136) Unknown identifier "j".
# ** Error: ../sim/sim_tb_top.vhd(662): Bad expression in left operand of infix expression "+".
# ** Error: ../sim/sim_tb_top.vhd(662): Actual (indexed name) for formal "bcs" is not a static signal name.
# ** Error: ../sim/sim_tb_top.vhd(716): (vcom-1136) Unknown identifier "j".
# ** Error: ../sim/sim_tb_top.vhd(716): Bad expression in left operand of infix expression "+".
# ** Error: ../sim/sim_tb_top.vhd(716): Actual (indexed name) for formal "bcs" is not a static signal name.
# ** Error: ../sim/sim_tb_top.vhd(767): (vcom-1136) Unknown identifier "j".
# ** Error: ../sim/sim_tb_top.vhd(767): Bad expression in left operand of infix expression "+".
# ** Error: ../sim/sim_tb_top.vhd(767): Actual (indexed name) for formal "bcs" is not a static signal name.
# ** Error: ../sim/sim_tb_top.vhd(814): VHDL Compiler exiting
# ** Error: E:/modeltech_6.5e/win32/vcom failed.
# Executing ONERROR command at macro ./sim.do line 69
# Model Technology ModelSim SE vlog 6.5e Compiler 2010.02 Feb 26 2010
# -- Compiling module HYB18T512160BF
# Top level modules:
#     HYB18T512160BF
# vsim +notimingchecks -L unisim -t ps -novopt work.sim_tb_top glbl
# Loading std.standard
# ** Error: (vsim-3173) Entity 'D:\xxx\DDR2\user_design\sim\work.sim_tb_top' has no architecture.
# Error loading design
# Error: Error loading design
#        Pausing macro execution
# MACRO ./sim.do PAUSED at line 74
You have not declared the variable j . should it be?
for i in 0 .. generate
 for j in 0 ....generate
FPGA freak
Anonymous
Not applicable
yes, j has not  been defined in anywhere.
this file is generated automatically by MIG,so i don't know how i can fix it.
thanks for your reply
Historian
Historian
the index variable in a for generate statement does not have to be declared.
Historian
Historian
The scope that contains the failing lines does not have j declared.
BTW: the disclaimer header at the top of your source, the one that says, "this disclaimer and copyright notice must be retained as part of this file at all times" ?? DELETE IT. It's YOUR code, not Xilinx'.
