DLC9G platform cable USB on my Windows 7 - Error when installing device driver
Hi All,
I encountered some issues when trying to use DLC9G platform cable USB on my Windows 7 professional laptop. I have ISE Design Suite 10.1 installed.
I have attached screenshot of the device driver that failed to install (I am not sure why there is a XILINX on 2nd device driver step)..
Anyone succesfully use DLC9G on Windows 7? I have tried to download the latest UG344 but it didnt work too.
Handi
Re: DLC9G platform cable USB on my Windows 7 - Error when installing device driver
Windows7 is not a supported OS.
However, there have been some reports that indicate running the tools in WinXP compatability mode does work.
Will this new programmer can support windows 7?
http://www.xilinx.com/products/devkits/HW-USB-II-G.htm
There is no support for Windows 7 at this time for Xilinx cables or software.
I am using the ise 12.2 version and facing the same problem as mention in this post earlier.....
Now is windows 7 is supported with the xilinx usb cable.....
Santosh
The previous posts were about the 10.1 and 11.1 software versions.  The 12.1 software does have Windows 7 support you will need to have administrator priviledges when you install the software.
