rob69
DMA user code problem
Dear forum
Im tryng to use DMA writing my code, using the driver provided by SDK.
Following the Adam tutorial , the wxample is working...I would like to understand
what is the problem of memory allignment. This mem allignment  test is done in
the driver function  named XDmaPs_BuildDmaProg(), in particular in 4 if() that i pase here.
Questions are before single if() ...............
//----------> This if() test if data Source Address is alligned with Burst Size .   Why is related to SrcInc ?????
if (ChanCtrl->SrcInc)
SrcUnaligned = SrcAddr % ChanCtrl->SrcBurstSize;
//------------------->Same question like before
if (ChanCtrl->DstInc)
DstUnaligned = DstAddr % ChanCtrl->DstBurstSize;
// What means ?????????
if ((SrcUnaligned && DstInc) || (DstUnaligned && SrcInc)) {
ChanCtrl = &Mem2MemByteCC;    // <---------------------------------point to other channel setting...
if (ChanCtrl->SrcInc) {
MemBurstSize = ChanCtrl->SrcBurstSize;
MemAddr = SrcAddr;
} else if (ChanCtrl->DstInc) {
MemBurstSize = ChanCtrl->DstBurstSize;
MemAddr = DstAddr;
/* check whether the head is aligned or not */
Unaligned = MemAddr % MemBurstSize;
Thanks for your time.
Roberto
muzaffer
@rob69 alignment is only an issue if burst is requested which is what SrcInc indicates.
rob69
Thanks for reply
looking at Channel Control Register of DMA, the src_inc bit tell if during the burst ,we want auto increment or not.
I understand it is not related to have or not a burst,
or not ?
If I dont want burst, just set Burst_len=1  (0 in register)
or not ?
thanks
rob69
Some news about this problem......??
