Data recovery unit in xapp881 and xapp523
Is anyone familiar with the reference code? I can follow its working to the state machine that chooses the samples and how the samples are registered, but do not understand what it does to the data afterwards to get a 10-bit vector.
In my application, I'd either need it to pass the data serially (to be registered later, I already have that bit written). I have an idea how to do it, but I'd basically have to write a completely new module, so I'd currently prefer adapting the existing one. Can maybe anyone guide me through the code so I see what does what?
Hi, did you get your answer eventually? Or did you figure it out?
I'm having the same problem: understanding the 10-bit wide output. what does it represent? Ho to retrieve the initial data from that bus?
Thank you
