fpga_freak
Declaring 2 D Ports in Verilog
  Anyone know, how to declare a 2-D port in Verilog.
regards,
freak
ywu
Verilog doesn't allow 2 dimensional ports.
Cheers,
Jim
woutersj
On a practical note: you have to fake this. To emulate a NxM bit 2-D port, use a vector of NxM. You can have the convenience of a 2-D array inside your module if you provide a conversion from the 1-D port to the 2-D easy representation. Waveform debugging of inter-module signals is of course a bit tedious.
AFAIK, SystemVerilog does allow 2-D ports but the Xilinx tools don't support that yet. It would probably be rather trivial to add this as it is supported for VHDL.
Cheers,
Johan
