Design Implementation problem
    To synthesize & implementing design for xc6slx150 device, can required license ISE tool or free ISE webpack addition is sufficient.
Hi Ganesh,
You cannot use ISE webpack for this device xc6slx150.
Check this IRN to know about the devices which are supported with ISE webpack
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_3/irn.pdf (page 37)
Go for some other edition.
Ankury
Hi Ganesh,
Ankury
The webpack license supports the below spartan-6 devices XC6SLX4-XC6SLX75T. You can get evaluation license which works for 30 days  and it can be obtained for free.
Deepika.
Deepika.
Thanks a lot ankur & Deepika !!
