asm2750
DocNav Change Request
Could we give DocNav on Windows an option to use <user>\AppData\Roaming\Xilinx\DocNav rather than <user>\AppData\Local\Xilinx\DocNav to store settings or at least store downloads.xml?
I work on a network that uses roaming profiles and everytime I log out and back in the Local directory gets wiped which means I need to copy a backup of the settings stored at <user>\AppData\Local\Xilinx\DocNav from a network drive so DocNav knows I've downloaded PDFs.
Maybe you guys have a solution already? Is there a way I can just stick downloads.xml in the install directory of DocNav and have the program just copy from there to my profile when I run it? (Or maybe I can edit one of the settings batch files to do the copy?)
vuppala
Hello @asm2750
Here is the option that helps you. See below snapshot:
Vinay
vuppala
Hello @asm2750
Vinay
asm2750
I tried it but that still doesnt help. Since the folder at "<user>\AppData\Local\Xilinx\DocNav" gets wiped out after logging out of my workstation it pretty much resets the settings to what they were when I first installed it. I'll just write a batch file to just copy a complete version of downloads.xml to the folder before starting the application.
