ssg10
Document to get started in microblaze embedded software programming?
I am a firmware/software engineer asked to get started in microblaze programming. Which docs do you recommend to start looking into?
balkris
you will get all required document here
http://www.xilinx.com/support/documentation-navigation/design-hubs/dh0015-sdk-hub.html
Thanks and Regards
Balkrishan
ssg10
Thanks. But, I am using vivado and SDK.  We have FPGA hardware engineers working on the RTL and I should be working on the microblaze firmware C code side.
SDSoC does not seem the one.  We are using ultrascale.
balkris
check documents here
http://www.xilinx.com/support/documentation-navigation/design-hubs/dh0057-sdsoc-hub.html
Thanks and Regards
Balkrishan
