Does ISE Design Suite Logic Edition include access to SDK and XPS?
Hi all,
in one month I am incorporating to a project in a company which is asking me if they have to buy any Xilinx software.
We are going to use ML605 Evaluation Board, in which specs I can read that it contains:  ISE Design Suite: Logic Edition. (Device-locked to the Virtex-6 LX240T FPGA).
I cannot find across Xilinx website the programs and licenses that are included in this Logic Edition.
I am going to work with MicroBlaze and I will need XPS and SDK.
Does anyone know if I will be able to use both programs with this Logic Edition? Should we buy a ISE D.S. Embedded Edition instead?
Thanks you very much.
Kind regards.
Ignacio Moreno.
Re: Does ISE Design Suite Logic Edition include access to SDK and XPS?
No, you cannot use XPS and SDK with logic edition.
You need Embedded edition or standalone EDK license.
Vinay
Please check http://www.xilinx.com/publications/matrix/Software_matrix.pdf
Thanks,Vijay
Vinay
