Driver Cell's full name
What’s the ‘Driver Cell’ full name(eg:RAMB18E2, SRLC32E, FDCE, FDRE, LUT2)?
where can I find a document introducing them?
Re: Driver Cell's full name
Hi @luoyanghero,
I am not sure if I understood properly. Are you looking for more info regarding FDRE, BRAM? If so you can get in HDL library user guide for example https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug974-vivado-ultrascale-libraries.pdf
If you are looking for RTL name of these primitives in your design then you can get from the schematics as told in my previous reply.
Arpan
Hi @luoyanghero,
Full name is given for probe5. It's arready_0.
For other probes you can get the net names by expanding the same.
Arpan
Hi @luoyanghero,
You can right click on the probe and click on schematic. In the schematic you can select the component to see the complete name.
Arpan
Not the signal's full name, but the Driver Cell's full name. For example:FDRE, it's a abbreviation of some words. I want to know it's explaination or it's completely spelling.
Hi @luoyanghero,
Arpan
