Dual port BRAM read unsuccessful from custom vhdl module
 I am implementing a shared memory. I am using axi dual port BRAM from XPS .port A is connected to microblaze and port B to my vhdl module that reads and write signals. I can read and write well from microblaze. But I can write successfully from vhdl code and when I tried to read a location it fails.It simply shows the data wrote previously, but I am trying to read from a different location that has different data. Any suggestions??w1.PNG
These are the connections in xps.Below given is my vhdl code :
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity bramblock is
   port
     RESET : IN std_logic;
                                FT2232_UART_SIN : IN std_logic;
                                CLK_100MHZ : IN std_logic;
                                axi_spi_0_SPISEL_pin : IN std_logic;
                                --axi_bram_ctrl_0_bram_block_1_BRAM_Rst_B_pin : IN std_logic;
                                --axi_bram_ctrl_0_bram_block_1_BRAM_Clk_B_pin : IN std_logic;
                                ---axi_bram_ctrl_0_bram_block_1_BRAM_EN_B_pin : IN std_logic;
                                --axi_bram_ctrl_0_bram_block_1_BRAM_WEN_B_pin : IN std_logic_vector(0 to 3);
                                --axi_bram_ctrl_0_bram_block_1_BRAM_Addr_B_pin : IN std_logic_vector(0 to 31);
                                --axi_bram_ctrl_0_bram_block_1_BRAM_Dout_B_pin : IN std_logic_vector(0 to 31);
                                rzq : INOUT std_logic;
                                mcbx_dram_udqs : INOUT std_logic;
                                mcbx_dram_dqs : INOUT std_logic;
                                mcbx_dram_dq : INOUT std_logic_vector(15 downto 0);
                                axi_spi_0_SCK_pin : INOUT std_logic;
                                axi_spi_0_MISO_pin : INOUT std_logic;
                                axi_spi_0_MOSI_pin : INOUT std_logic;
                                axi_spi_0_SS_pin : INOUT std_logic;
                                mcbx_dram_we_n : OUT std_logic;
                                mcbx_dram_udm : OUT std_logic;
                                mcbx_dram_ras_n : OUT std_logic;
                                mcbx_dram_ldm : OUT std_logic;
                                mcbx_dram_clk_n : OUT std_logic;
                                mcbx_dram_clk : OUT std_logic;
                                mcbx_dram_cke : OUT std_logic;
                                mcbx_dram_cas_n : OUT std_logic;
                                mcbx_dram_ba : OUT std_logic_vector(1 downto 0);
                                mcbx_dram_addr : OUT std_logic_vector(12 downto 0);
                                GPIO_HEADER_P2_PORT0 : OUT std_logic_vector(31 downto 0);
                                FT2232_UART_SOUT : OUT std_logic;
                                --axi_bram_ctrl_0_bram_block_1_BRAM_Din_B_pin : OUT std_logic_vector(0 to 31);
      d : in std_logic;
      q : out std_logic;
                                chk: out std_logic
end entity bramblock;
architecture Behavioral of bramblock is
signal add1:std_logic_vector(0 to 31) :=(others=>'0');
signal we1: std_logic_vector(0 to 3):=(others=>'0');
signal en1:std_logic:='0';
signal cnt:std_logic:='0';
signal dout1 :  std_logic_vector(0 to 31):=(others=>'0');
signal din1 :  std_logic_vector(0 to 31):=(others=>'0');
signal start:  std_logic_vector(31 downto 0) :=(others=>'0');
COMPONENT system
                PORT(
                END COMPONENT;
                attribute box_type : string;
                attribute box_type of system : component is "user_black_box";
begin
Inst_system: system PORT MAP(
                                RESET=>RESET,
                                FT2232_UART_SIN =>FT2232_UART_SIN ,
                                CLK_100MHZ =>CLK_100MHZ,
                                axi_spi_0_SPISEL_pin=>axi_spi_0_SPISEL_pin,
                                axi_bram_ctrl_0_bram_block_1_BRAM_Rst_B_pin =>'0' ,
                                axi_bram_ctrl_0_bram_block_1_BRAM_Clk_B_pin =>CLK_100MHZ,
                                axi_bram_ctrl_0_bram_block_1_BRAM_EN_B_pin =>en1,
                                axi_bram_ctrl_0_bram_block_1_BRAM_WEN_B_pin =>  we1,
                                axi_bram_ctrl_0_bram_block_1_BRAM_Addr_B_pin =>  add1,
                                axi_bram_ctrl_0_bram_block_1_BRAM_Dout_B_pin =>  dout1,
                                rzq =>    rzq,
                                mcbx_dram_udqs =>      mcbx_dram_udqs,
                                mcbx_dram_dqs =>mcbx_dram_dqs,
                                mcbx_dram_dq =>           mcbx_dram_dq ,
                                axi_spi_0_SCK_pin =>    axi_spi_0_SCK_pin,
                                axi_spi_0_MISO_pin=>axi_spi_0_MISO_pin,
                                axi_spi_0_MOSI_pin =>axi_spi_0_MOSI_pin,
                                axi_spi_0_SS_pin =>axi_spi_0_SS_pin,
                                mcbx_dram_we_n =>mcbx_dram_we_n,
                                mcbx_dram_udm =>       mcbx_dram_udm,
                                mcbx_dram_ras_n =>mcbx_dram_ras_n,
                                mcbx_dram_ldm =>mcbx_dram_ldm ,
                                mcbx_dram_clk_n =>mcbx_dram_clk_n,
                                mcbx_dram_clk =>mcbx_dram_clk,
                                mcbx_dram_cke =>mcbx_dram_cke,
                                mcbx_dram_cas_n =>mcbx_dram_cas_n ,
                                mcbx_dram_ba =>mcbx_dram_ba,
                                mcbx_dram_addr=>        mcbx_dram_addr,
                                GPIO_HEADER_P2_PORT0 =>start,
                                FT2232_UART_SOUT =>FT2232_UART_SOUT,
                                axi_bram_ctrl_0_bram_block_1_BRAM_Din_B_pin =>din1
GPIO_HEADER_P2_PORT0<=start;
process (CLK_100MHZ) is
   begin
      if rising_edge(CLK_100MHZ) then
         if (RESET='0') then
        if(start(0)='1') then
        if(cnt='0') then
        add1<=(0=>'1',2=>'1',6=>'1',28=>'1',others=>'0');
        en1<='1';
        we1<=(others=>'1');
        dout1<=(29=>'1',31=>'1',others=>'0');
        cnt<='1';
        elsif (cnt=1)then
        add1<=(0=>'1',2=>'1',6=>'1',27=>'1',others=>'0');
        en1<='1';
        we1<=(others=>'0');
        dout1<=(others=>'0');
        cnt<=cnt+1;
        else
        add1<=(others=>'0');
        en1<='0';
        we1<=(others=>'0');
        cnt<='1';
                                                end if;
                                                end if;
         end if;
      end if;
   end process;
chk<=start(0);
end architecture Behavioral;
please make any suggestions.
Re: Dual port BRAM read unsuccessful from custom vhdl module
I finally figured my error. You have to look for the value in read bus only after one more elsif (..) idle case since the value comes in bus with 1 clock time delay...
check this documents
http://esca.korea.ac.kr/teaching/com509_CS/zynq/zedboard_xup/Vivado-based/ES-Design-Vivado-13.3/doc_source/lab3.pdf
http://www.uz.zgora.pl/~rwisniew/instrukcje/sw/sw_cw3.pdf
Thanks and Regards
Balkrishan
 Thank you for replying, But those documents were based on how to add BRAM as peripheral. But I want to develop a shared memory on which you can operate from microblaze and vhdl code. I am facing difficulty in reading memory from vhdl. And need help in that.
Also in 'else' case in vhdl code cnt<=cnt....
