EDK platgen fails when building hardware
Hello All,
We tried migrating our license from one PC to another PC (Windows 10). We got the following error during the build.
"ERROR:EDK - platgen failed with errors! 15:15:31 make.exe[3]: *** [implementation/system_pcp_intc_wrapper.ngc] Error 2."
Through a separate SR we got confirmation that this is not a licensing error.
Kindly help us with the issue.
Thanks & Regards,
Kalycito
check this related ARs
https://www.xilinx.com/support/answers/53486.html
Thanks and Regards
Balkrishan
