Error in showing image on monitor2
in continous of my last message, I'm trying to resolve shifting image problem.
I think READ LATENCY can make this problem, because the start point of image is shifted to right. How can I find how many pixels was lost?. It seems the end part of  each line of image is out of monitor.
Could you please guide me? How can I fix read latency problem? Does it make this problem?
About horizontal timing I've checked all frequency of design, they're correct.
Re: Error in showing image on monitor2
Have you fully analyzed and cross checked on Bob inputs in your earlier post, Strongly  belive one among the below points will cause the pixel shift.
miscoded decodes of horizontal (pixel) counters
incorrect timing for transmitting the SAV (start of active video) flags
incorrect starting address for reading the DRAM video buffer (for each video line)
incorrect address for writing to the video buffer (for each video line)
One way is you can transmit  a fixed color data in place of video to check the number of pixels missing in the left edge, this will reval if your counters are mistaken are the video/bmp  data has shift.
Vanitha
