Ethernet Module Needed
Hi all,
         Can anyone send me a simple module in ISE or BSB to send/ receive a file on ethernet port.
I am using spartan 3e 500e starter kit
I planned to send a file/ data from the board to PC and viceversa.
I want to use any one of the protocol either TCP or UDP.
I am presently using xilkernel OS but may remove if needed.
I have small knowledge of lwip and socket programming.
The proper core is not available on  http://www.opencores.org
I am able to add IP cores of the ISE core generator but user interface is not easy to design so i am unable to design a Ethernet controller user interface.
There are various documents available on internet but according to my need i have found nothing for file/ data transmission.
I tried to search using google also.
sujeet
Mentor
Mentor
Re: Ethernet Module Needed
No.
Even if I wanted to, I couldn't help you, because there's hardly any information in your post. Some hints:
  • What FPGA are you using?
  • What board?
  • How are you planning to interface with the Ethernet port?
  • Do you want to use TCP, UDP, or even a custom protocol?
  • Do you already have a SoC set up? Is it running an operating system?
  • What do you already know about Ethernet PHY/MAC?
  • Have you googled for your problem?
  • Have you looked at the IP cores of the ISE core generator? Have you looked at cores on http://www.opencores.org ?
Ask a specific question, and someone will help you. However, we're not here to do your job and/or read your mind.
Adrian
Please google your question before asking it.
If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
sujeet
Would the Ethernet lite core in EDK work for you?
http://www.xilinx.com/support/documentation/ip_documentation/xps_ethernetlite.pdf
sujeet
Cheers,
Jim
