Forum HTML editor, invalid HTML error
when using the HTML editor in the community forums, the following code throws an error message:
<h1>heading</h1>
Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied.
Is this intended? Which html tags are allowed? It is not mentioned in the community_guidelines
florentw
Hi @theultimatesource,
Yes I think this is intended to have only some html tags allowed. Mainly those to match the "Rich Text" editor.
florentw
