Anonymous
Not applicable
General question on metastability
Hi All,
Often in digital design, when we use RAM, counters, shift register, an Enable signal is used in a a similar fashion(RAM):
process(clk)
    begin
        if(rising_edge(clk)) then
            if(we = '1') then
                ram(addr) <= data;
            end if;
The question is, what happens if the rising edge of clock (clk) happens at the same time when "we" goes from low to high?  Is that  metastability( although in the same clock domain)?
Do I need as a designed to make sure "we" signal high occurs  before rising_edge of clock( setup time >0) or I am safe?
thank you
LT
Instructor
Instructor
In addition to Gabor's excellent comment:
In your example, the following signals must meet setup and hold timing requirements with respect to the clock positive edge:
  • we
  • addr
  • data
If the setup/hold time requirements are not respected, result (ram content/state) will be indeterminate.
Check the device datasheet for specific timing requirements.
-- Bob Elkind
SIGNATURE:
Summary:
Professor
Professor
To avoid the possibility of metastability you need to meet setup and hold time to the
clock for the we signal.  Normally if we is also assigned in a clocked process, the
tools will take care of this for you.  In general it is a bad idea to use an asynchronous
signal to drive the we input of the RAM.
-- Gabor
-- Gabor
Instructor
Instructor
  • we
  • addr
  • data
-- Bob Elkind
SIGNATURE:
Summary:
Anonymous
Not applicable
Meeting setup and hold times for "we" signal make sense. I thought that setup and hold times refer only to data with respect to clock relationship.
LT
Instructor
Instructor
And then there's address, of course.
-- Bob Elkind
SIGNATURE:
Summary:
