Generating the global reset : ZC702 ZYNQ platform ...
I have imported XPS system to ISE and I need to use the global reset. In the imported system,
processing_system7_0_PS_SRSTB : IN std_logic;
is the reset pin for processing system. However, in UCF I can only see
NET "PS_SRSTB"   IOSTANDARD = LVCMOS18 | DRIVE = "8" | SLEW = "slow" | LOC = "C9" ;
1) What is the correct way of generating the global reset (in top module)?
2) If processing_system7_0_PS_SRSTB buffer the PS_SRSTB internally (in PS system), how to generate global reset?
Thank you.
Re: Generating the global reset : ZC702 ZYNQ platform ...
Is it possible to make an external reset pin (to reset PL design in VHDL) from ZYNQ-7000 platform?
The PS system "Reset" block (in XPS) can't be edited.
Thank you.
I have found the answer and it is in,
LogiCORE IP Processor System Reset Module (v3.00a) datasheet.
Link : http://www.xilinx.com/support/documentation/ip_documentation/proc_sys_reset.pdf
Visitor rusevm
But that's not solving it for an ISE editor. What pin could you use/ io core to generate global reset under project navigator?
