Generic question
Hey.
I have a question about the usage of generics.
Lets say I have the following user logic (without the ports)
entity user_logic is
  generic
    -- ADD USER GENERICS BELOW THIS LINE ---------------
    Clk_num_2_us_Delay             : std_logic_vector     := X"000000C8";
     Clk_num_250_ns_Delay           : std_logic_vector     := X"00000019";
     Clk_num_30_ns_Delay             : std_logic_vector     := X"00000003";
     Clk_num_40_ns_Delay             : std_logic_vector     := X"00000004";
    -- ADD USER GENERICS ABOVE THIS LINE ---------------
    -- DO NOT EDIT BELOW THIS LINE ---------------------
    -- Bus protocol parameters, do not add to or delete
    C_SLV_DWIDTH                   : integer              := 32;
    C_NUM_REG                      : integer              := 3
    -- DO NOT EDIT ABOVE THIS LINE ---------------------
In the upper level I also get those generics from the generics map
entity ad7655 is
  generic
This is the instantiate
USER_LOGIC_I : entity ad7655_v1_00_a.user_logic
    generic map
      -- MAP USER GENERICS BELOW THIS LINE ---------------
        Clk_num_2_us_Delay => Clk_num_2_us_Delay,
       Clk_num_250_ns_Delay  =>  Clk_num_250_ns_Delay,
       Clk_num_30_ns_Delay => Clk_num_30_ns_Delay,
       Clk_num_40_ns_Delay => Clk_num_40_ns_Delay,
My question is about the defualt value of those generics.
for example
Lets say I set Clk_num_2_us_Delay  to X"000000C0" in the XPS.
Wouldn't it be set again to X"000000C8" in the user logic?
Thanks a lot.
Assaf.
Re: Generic question
Hi assaf,
no. The purpose of having a default is to be overwritten by an actual value.
When a generic is declared in an entity, the assigned value acts as a default UNLESS no assignment is made in the generic map of the instantiation.
Different instantiations of the same model can assign different values to the same generic.
e.g. you have a counter model with a generic that is set to 8, thus creating a 8 bit counter by default.
Your toplevel can then have numerous instances of this model and so you may get 4, 8, 13 and 43 bit wide counters.
Remember, each instance creates independent hardware.
Have a nice synthesis
  Eilert
Hi assaf,
  Eilert
