HLS and ISE
Hi~
      I have finished my design in HLS,I want to see the RTL of my design in ISE, what  should I do specifically? Are there some documents beside HLS User Guide I may learn?
     Thank you!
Download 2013.4 Documentation Navigator from the link - link and install it.
After installation and opening it, you will find a Design Hub View where there is a link for All HSL Video and documenation and App notes as shown below.
Anirudh
PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.
Other HLS guide link - link
Anirudh
When you say "finished my design in HSL" do you mean you were able to synthesize your c/c++ code and code generation worked without errors? If so, the output(s) are available in solutionX/syn directory: solution1/syn/verilog etc.
Yeah, thank you!
Thank you !
