venky228
Help Regarding ADC
hello
         i'm a student using ALTIUM NANO BOARD 3000. i'm having the vhdl code for reading any one channel of ADC(adc084s021) for nano board. Now i want to use the two channels of ADC and my output should be subtraction of two channels , when i edited my code i'm getting errors.  i'm attaching my code files for reading single adc channel here.                 plz help me....
                 thanks in advance..........
rcingham
"when i edited my code i'm getting errors"
What errors?
venky228
first of all thanks for the reply sir......
        the code which i attached is for reading only one adc channel. i was getting output in leds. now i want to use two channels. i just changed the channel and repeated the same component adc084s021(present in code). i got the error that adc clock is driven through multiple sources......   i have to get the output as
                                  output= channel1(data) - channel2(data_
can you please tell me the necessary changes i can make in my code to get the required output.
                        thanks in advance
eteam00
Professor
Professor
The variable for the adc clock may be assigned in only one process.  Search your code and combine the processes or eliminate all the adc clock assignment statements outside a single process.
-- Bob Elkind
SIGNATURE:
Summary:
