Visitor ihtesham1985
How can we force net lengths to be equal in Vivado??
hi,
I am trying to implement a basic combinatorial circuit with two cross coupled latches (shown in figure below).  I need to ensure the length of two cross-coupling nets (connecting Q and D to be of equal lenth). How can I force length of two nets to be (approximately) equal in vivado?
Best Regards,
Ihtesham
Historian
Historian
Re: How can we force net lengths to be equal in Vivado??
Short answer is "you don't". FPGAs just aren't built for things like this. The entire FPGA tool chain is designed to be used for synchronous design - it doesn't deal with things like this (basically at all). So, there is no way to force nets to be the same length via "normal" operations.
The only way you might be able to do this is by manually placing the cells and routing the nets yourself. To do this, you are going to have to get intimately familiar with the routing channels and switch matricies between CLBs...
The next question is "why on earth would you want to do something like this?"
Avrum
