How do I contact a FAE?
I cannot find how to contact a Field Application Engineer(FAE). Can someone point me to a way to get contact? Thank You
Well,
First, if you buy from an authorized Xilinx distributor (example:  Avnet, your would call them).  A quick online search shows you start with their (Avnet) sales support.
https://products.avnet.com/wps/portal/ema/about-us/contact-us/!ut/p/z1/hc6xCsIwGATgZ_EJctE0NuNvrGkwqSW0WrNIJilodRCf31K6qrcdfAfHIutYHNK7v6ZX_xjSbeznKC-51dLuBXeHepuBam4lR-mrbM1OE8CXEFj8t48TMSqzXGt4NEGOZLU7FjyYlsQMHKmiJCydafwGpNogtKuAHDP48eF579BbWnwALrC...
If you buy directly from Xilinx, you go to a Xilinx sales support center.  They then help you get in touch with the right FAE (some are specialists, some are generalists, so we need to figure out who is best.
https://www.xilinx.com/about/contact/sales-offices.html
There service portal is also a place to start:
https://www.xilinx.com/support/service-portal.html
Hope that helps.
Of course, asking here may be the fastest way to get an answer.
Austin Lesea
Principal Engineer
Xilinx San Jose
Excellent! Thank You
