05-30-2013 07:41 AM
Recently, i met a problem about axi vdma fsync setting.
In my project, I want to use one AXI VDMA and AXI Pcore for algorithm accelerating on Zedboard. My data flow is DDR->VDMA MM2S-> PCORE->VDMA S2MM->DDR
if fsync = 0, axi vdma runs in free, VDMA and PCORE runs OK. Moreover, according this recommendations http://www.xilinx.com/support/answers/53281.html, set FSYNC = 3, C_USE_FSYNC = 3 and change the S2MM_DMACR register to 0x10043, the results are error. i upload my EDK project.
------------SW-------
The registers status is here(the hsize = 316*16, vsize = 252):
VDMA WRITE Channel Status:
PARKPTR = 0x00000000
S2MM_DMACR = 0x00010043
S2MM_DMASR = 0x00010000
S2MM_STRD_FRMDLY = 0x13C0
S2MM_START_ADDR0 = 0x10000000
S2MM_HSIZE = 316*16
S2MM_VSIZE = 252
S2MM_HSIZE_STATUS= 0x00000000
S2MM_VSIZE_STATUS= 0x00000000
VDMA READ Channel Status:
MM2S_DMACR = 0x00010003
MM2S_DMASR = 0x00010000
MM2S_STRD_FRMDLY = 0x13C0
MM2S_START_ADDR0 = 0x12000000
MM2S_HSIZE = 316*16
MM2S_VSIZE = 252
Is there any problem about the VDMA configuration?
Best Regards!
05-30-2013 12:40 PM
05-30-2013 07:58 PM
The output data form pcore processed is error When setting FSYNC = 3, but output data from pcore processed is correct when setting FSYNC = 0.
I suspect the problem may be the vdma configuration.
05-31-2013 08:08 AM
06-02-2013 04:53 AM
Thank you for reply. First, let me introduce my project as shown in the image.
Now setting FSYNC = 0 for vdma0 and vdma1, i just use nano_sleep for waiting vdma I/O communication, it works OK. but there are some bugs.
Problems:
1. When my pcore have high latency, the vdma s2mm channel transfers the unexpected results. For example, when i intergrat two pcores into only one pcore, unfortually, the results are not proper.
2. Sometimes the bottom few lines are not proper, sometimes it works OK.
So i think FYSNC = 3 is a better mode for my project, and I try to debug VDMA FSYNC=3 mode.
