How to continue running FPGA when external clock fails?
Customer is supplying external clock to run system FPGA. If clock fails need to place system into safe mode. Any ideas on how to continue running FPGA when external clock fails?
Greatly appreciate any advice.
Thanks!
Re: How to continue running FPGA when external clock fails?
Usually systems that have this sort of requirement get a pending clock failure indicator and have a limited time to "go into safe mode".
Mentor
Mentor
The STARTUPE2 block has a CFGCLOCK output.   It's not super stable, or precise... but it's a workable clock you can use as a fallback to do some basics.   I'm assuming your FPGA is a series 7 or later device.     You can use it to run a clock detection circuit, and switch your clock tree to the CFGCLOCK if needed.
Advisor
Advisor
Another approach is to add a local reference clock to the board. Optical communications equipment is nearly always designed to have a holdover mechanism that kicks in if the external reference clock disappears. The master PLL can failover to the local reference. I wonder if this is possible with Xilinx PLL's.
DSP in hardware and software
