amingcha
How to migrate ps7 IP v5.4 to v5.5 ?
I have a project developed using Vivado 2014.2. This project contain ps7 v5.4
But, now I am using Vivado 2014.4  which supports ps7 v5.5
How can I upgrade the ps7 v5.4 to v5.5 ? When I use the IP report status to upgrade the IP it gives me the error shown in the attached picture.
Do I need to uninstall Vivado 2140.4 and install the Vivado 2014.2 again?
Thank you
Andre
pratham
I just tried a zynq project from 2014.2 and opened it in 2014.4. I was able to migrate it easily.
Can you send me the vivado.log?
-Pratham
siktap
This seems an issue. Is it possible to delete zynq IP from 2014.4 and readd that IP again for your bd?
Sikta
yashp
run report_ip_status command in TCL.
Then check the IP which you want to upgrade.
Yash
pratham
-Pratham
amingcha
I solved the problem by uninstally vivado 2014.4 and reinstalling vivado 2014.4
Thanks for the help.
