Visitor damone
How to read and Understand the xilinx part numbers and abbreviations, model numbers
    I am new to this site and also to FPGA. I would like to buy xilinx Virtex board and it reads as Virtex 5 LX FPGA FF 1760.
What is the following?
Virtex
LX
FF 1760
XC5
VLX110
Kind enough to help me how to read and understand naming specifications.
Re: How to read and Understand the xilinx part numbers and abbreviations, model numbers
Gabor answered your query well. According to that I am giving one example description for more clarity
An example of an ordering code for a Xilinx FPGA is XC4VLX60-10FFG668C. The
ordering code stands for:
XC4VLX – Family (Virtex®-4 LX)
60 – Number of system gates or logic cells (60,000 logic cells)
-10 – Speed grade (-10 speed)
FFG – Package type (Pb-free flip-chip BGA)
668 – number of pins (668 pins)
C – Temperature grade (Commercial)
Mentor hgleamon1
Mentor
Perhaps reading the Virtex 5 datasheet could help?
Link to datasheet here -> DS100
"That which we must learn to do, we learn by doing." - Aristotle
An example of an ordering code for a Xilinx FPGA is XC4VLX60-10FFG668CS2. The
XC4VLX – Family (Virtex-4 LX)
S2 – Step 2
You can check the packaging guide for the part/package marking.
Also to determine valid ordering combinations for a given device, consult the device data sheet as posted by other user in the earlier post.
Deepika.
Deepika.
Scholar pratham
VIrtex- Family Name
LX- Device type(use for High-performance general logic application)
FF 1760- Package Type Flip-chip package.
XC5-Xilinx 5th Series.
Pratham
-Pratham
Instructor
Instructor
I believe the XC is "Xilinx Commercial" - however this particular "C" relates to application, not temperature range.
There is also XA ("Xilinx Automotive")
Virtex is just a marketing name for the high-end chip series.  Spartan was the low-cost (bare bones?) series.  Artix is the new low power low cost (perhaps intended to sound like Arctic?) series.  Kintex is the new middle-class series.  I think the new Xilinx naming conventions are intended to sound a bit more Altera-like, something like the "New Coke" tasted more like Pepsi.
For some reason, the Name and Series Number are swapped in the part number, so Virtex 5 becomes 5V, Spartan 6 becomes 6S, etc.
Within a family there are devices optimized for different applications like
LX - General Logic, No transceivers
LXT - General Logic with Transceivers
FX - Embedded hard processor
The numeric part of the device number has changed from family to family, but most newer families use the approximate number of "logic cells" in thousands.  So in your case the 110 means about 110 thousand logic cells, where a logic cell is not directly related to an internal structure but represents a marketing equivalent of some theoretical cell that contained a 4-input LUT and a flip-flop.  You need the data sheets to find actual LUT size and count.
At the end of the part number is the speed grade, package, and temperature grade.  For Xilinx parts, higher speed grade is faster (-3 is faster than -2).
FF1760 indicates a flip-chip BGA, with 1760 balls.  You need to find the package drawing to get the ball spacing, but for most "FF" packages this would be 1.0mm
-- Gabor
Visitor damone
Thank you very much
Visitor damone
thank u very much
