yazdian
How to simulate dru.ngc in design files of XAPP1076
I want to simulate design files of XAPP1076 but there exists a NGC file "DRU.NGC" which I require a simulation model file for that to use in Modelsim simulator.
I have created this simulation file using NETGEN, but it seems that the contents of the generated file is encrypted and thus modelsim could not work with that.
Could anyone guide me on this issue.
gszakacs
Instructor
Instructor
You could always run a post-translate simulation.  If you set the synthesis to "keep hierarchy" then
even though the netlist is not as nice as for behavioral simulation, at least you have a chance of
finding signals where you expect to see them.
Which version of ModelSim are you running?
-- Gabor
yazdian
Thanks for your reply.
I tried to generate the post-translate model and again I encountered the same problem.
Attached you can find the translat simulation model. The contents of the file seems to be encrypted !!
ywu
Your best bet is to work with your FAE or open a webcase to get an encrypted simulation for modelsim.
Cheers,
Jim
