smileworker2012
How to use pow function in HLS with C?
      I dad write "#include <math.h>" in my code. However there's still the error " math function 'pow' is not supported for synthesis".Which C library shoud I choose or whice function shoude I use to get number's power?
     I tried to write the pow function myself to get the power of 2 ,codes like:
            int power_func(int n)
                   int power=1,k;
                   for(k=0;k<=n-1;k++)
                          power=power*2;
                  return power;
      The trip count and lentancy both are "?". Maybe because n is an variable.
      What can I do for the power?
      Thanks a lot!
muzaffer
Do some algebra:
By definition pow(x,y) = exp(y*log(x)).
Both exp and log are available for synthesis.
muzaffer
Do some algebra:
smileworker2012
Thank you!
