How to write an advanced Timing constraint?
I use the word advance because I know the basic of how to constraint in a ucf file. The basic stuff includes assigning pins to corresponding outputs and inputs of top module and configure the clock pin period.  But there are a lot more constraints than just LOC and PERIOD. And for those other constraints, I don't know when or why should I use them and what value should I choose. I use Constraint Guide from Xilinx as a reference. But it's just a reference not a textbook or tutorial type of material. So I would like know how do you guys learn timing constriants and is there any book or blog or tutorial that you recommendded?
Thanks for help.
Re: How to write an advanced Timing constraint?
I refer UG612 http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_2/ug612.pdf for learning timing constraints related to UCF.
This UG you can refer as bible :)
Yash
hi,
there are a few vidoes.
refer http://www.xilinx.com/training/fpga/global-timing-constraints-video.htm
this is for timing closure http://www.xilinx.com/training/fpga/timing-closure-video.htm
http://www.xilinx.com/training/fpga/achieving-timing-closure-video.htm
--hem
Yash
