IP core license
I have an IP CORE of tri-speed mac with was purchased in 2009.
How can I renew this license to work with different hostID ?
Many thanks
Can you attach your license file here?
for example, If you purchased the license in august 2009, the license will be valid till July 2010 (1 year) i.e., all the versions of tri-speed mac IP that are released before July 2010 can be used with this license.
Regarding your query on rehosting the license, follow the steps mentioned in following answer record: http://www.xilinx.com/support/answers/42405.html
Vinay
