05-18-2011 07:22 AM
I just installed ISE 13.1 (0.40d) on my Debian Squeeze box. If I open a shell window and type:
$ source /opt/Xilinx/13.1/ISE_DS/settings32.sh
then apt commands no longer work,
$ apt-cache search gcc
apt-cache: /opt/Xilinx/13.1/ISE_DS/common/lib/lin/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by apt-cache)
apt-cache: /opt/Xilinx/13.1/ISE_DS/common/lib/lin/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by apt-cache)
apt-cache: /opt/Xilinx/13.1/ISE_DS/common/lib/lin/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/libapt-pkg.so.4.10)
apt-cache: /opt/Xilinx/13.1/ISE_DS/common/lib/lin/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /usr/lib/libapt-pkg.so.4.10)
It seems that ISE installed a version of libstdc++ (6.0.8) that is not compatible with my system. Can I just remove the library from the Xilinux path and use the libstdc++.so.6.0.13 that is installed by default with squeeze?
--wpd
05-18-2011 09:26 AM
You can always open a fresh terminal window (i.e. without sourcing settings32.sh) and run apt from the new terminal.
@wpd wrote:
--wpd
05-18-2011 09:32 AM
yep... that's not the issue.
The issue is that I am trying to run some scripts that happen to use apt utilities as well as Xilinx utitliies. I suspect that apt isn't the only application affected by this. It just happens to be the first one that I noticed.
Thanks for the quick reply. I appreciate it.
--wpd
05-18-2011 11:12 AM
I see. Things like this happen when you use the IDS tools outside supported OSes. Sorry I don't know your environment enough to give you suggestions on how to resolve your problem. Having said that, one of things I like Linux is with enough hacking and persistence you can always make things work harmoniously in the end.
--wpd
05-18-2011 05:59 PM
Perhaps your script could fork a new shell that loads the Xilinx environment variables, runs the Xilinx tools, and then exits?
It's a bit fiddly, but should work.
05-18-2011 10:59 PM
linux has a mechanism of aliasing libraries.
So you can fake the appearance of your libstdc++.so.6.0.13 to look like libstdc++ (6.0.8).
This works fine in many cases.
But there may be rare cases when some truly incompatible functions are called, causing the program to do somthing wrong, or even crash.
Have a nice synthesis
Eilert
