ISE 13.1 via command line
I've been trying to write a batch file to run everything through command line.
I got ISE working but I am getting errors dealing with EDK and SDK.
Here is lines that used for EDK
%EDK%\make.exe -f %DEEPSAS%\lanFPGA\synthesis\lanFPGA.make clean
%EDK%\make.exe -f %DEEPSAS%\lanFPGA\synthesis\lanFPGA.make netlist
%EDK%\make.exe -f %DEEPSAS%\lanFPGA\synthesis\lanFPGA.make exporttosdk
It seems like clean and exporttosdk work just fine but I am getting following error while building netlist:
process_begin: CreateProcess(NULL, platgen -p xc5vsx50tff665-1 -lang verilog -to plevel no -ti lanFPGA_i -msg _xps/ise/xmsgrops.lst lanFPGA.mhs, ...) failed.
make (e=2): The system cannot find the file specified.
make: *** [implementation/mb_plb_wrapper.ngc] Error 2
Not quite sure what kind of file it is looking for, its pretty cleat that it is not lanFPGA.make file.
I was wondering if someone might know solution to this problem or at least a hint.
Thank you very much
I also get problems with SDK but I am going to post it to a different thread.
Alright, its fixed for sure!!!!
Here is what I have done:
A. Set the environment variable XILINX
Windows XP Professional
  Globally:
  1. Right-click My Computer, and select Properties.
  (NOTE: "My Computer" will be located under the "Start" menu if it is not on the desktop.)
  2. Click the Advanced tab.
  3. Click Environment Variables, and add the desired variable.
Variable: XILINX Value: C:\Xilinx\13.1\ISE_DS\ISE
B. Included bunch of different pathes tsearch path for executable files (I think %LIB% one is crucial)
   if "%SYNTH%" == "" set SYNTH=C:\path\to\your\synthesis\
if "%ISE%" == "" set ISE=C:\Xilinx\13.1\ISE_DS\ISE\bin\nt if "%EDK%" == "" set EDK=C:\Xilinx\13.1\ISE_DS\EDK\gnuwin\bin if "%XPS%" == "" set XPS=C:\Xilinx\13.1\ISE_DS\EDK\bin\nt
if "%LIB%" == "" set LIB=C:\Xilinx\13.1\ISE_DS\ISE\lib\nt
path=%ISE%;%XPS%;%EDK%;%LIB%;%SYNTH%
Took only couple days to figure out, I wish make.exe error handler would give more info than just "the system cannot find the file specified"
Does the variable "%DEEPSAS%" point to a directory with spaces in it?  If so, then you need to put quotes around the entire string so it will be passed as one item.
I dont think I have any spaces in the definition of DEEPSAS. I think my path variable is defined properly, otherwise clean and exporttosdk calls would not work either.
I think I fixed it!
You have to run batch file as administrator to make it work
  Globally:
If you open a DOS command window using Start -> Xilinx Design Suite 13.1-> Accessories->ISE Design Suite Command Prompt, it will automatically set up all the environment variables for all IDS tools.
  Globally:
Cheers,
Jim
