12-07-2016 05:49 AM
I have a design I'm currently working on and some of the vhdl files disappeared from the "files" tab in ISE (I honestly don't know what I did to make them disappear). They are even showing up as "?" next to their instantiated names in the Design hierarchy.
I also want to note have an EDK project in this design that uses the same vhdl files that disappeared.
I went to add the files back in to the design but I'm getting a popup that states they already exist. Any ideas as to how to resolve this issue?
12-07-2016 05:51 AM
I forgot to mention that I'm working in ISE 14.5
12-07-2016 07:27 PM
Hi @ngrubaugh
I suspect the files are in project directory which results in a pop-up "the files are already exists".
Can you try "Project --> CleanUp Project files" and check whether the files are still shown as "?"?
Also are you encountering any issues in synthesis or implementation though the files are shown as "?"
Vinay
12-08-2016 04:57 AM
Yes, I tried to run the Cleanup Project Files option previously and the blocks are still being shown as unknown and I couldn't re-add the vhdl files either.
I just reverted to an older load of the project and reworked the changes and that seems to have fixed the problem. I guess I won't figure out what caused the error!
Thanks!
