Implement CPRI by the SFP+ connector on KC-705
Hi All,
I followed the document (PG053) and generated a CPRI of 6.25 Gbps by core generator.
It works if connected by SMA as the document illustrate.
However, when I tried change the GTP from SMA connectors to SFP+ connectors by changing the ucf file as the following:
original: INST "cpri_block_i/gt_and_clocks_i/gtwizard_i/gt0_gtwizard_i/gtxe2_i" LOC = "GTXE2_CHANNEL_X0Y8";
modified: INST "cpri_block_i/gt_and_clocks_i/gtwizard_i/gt0_gtwizard_i/gtxe2_i" LOC = "GTXE2_CHANNEL_X0Y10";
The generated bit stream is not work and the indicator shows the clock seems some problems. (plz refer to the attachment) I checked and verified the connection of the X0Y10 instance, it shares the same clock with X0Y8 in another example.
Is there something I did not notice?
Thanks in advance
Best Regards
Amistad
normal indicator
Abnormal indicator
Tags (3)
