Visitor panfei
Initial Value for Distributed Ram not working in Planehead
Hello, everyone. I desgined a 2 read 1 write ram with initial value. When I try to set the ram_style as "distributed", the initial value becomes all 0 instead of the right one. I am using Planahead 14.4 for ML505 (Virtex-5)
Here is my VHDL code for definition and initialization of RAM:
TYPE RAM IS ARRAY (RAM_SIZE-1 DOWNTO 0) OF bit_vector(DATA_WIDTH-1 DOWNTO 0);
 FUNCTION init_ram return RAM is
   variable tmp: RAM; -- := (others => (others => '0'));
 begin
   for I in RAM'range loop
     tmp(I) := to_bitvector(std_logic_vector(to_unsigned(integer(real(MEMORY_BASE_ADDRESS) + real(BUCKET_SIZE) * real(I)), DATA_WIDTH)));
   end loop;
   return tmp;
 END init_ram;
 SIGNAL ram_inst : RAM := init_ram;
 attribute ram_style: string;
 attribute ram_style of ram_inst : signal is "distributed";
Teacher xilinxacct
Re: Initial Value for Distributed Ram not working in Planehead
@panfei
Are you setting the local array value instead of the RAM as you intend?
