Visitor dprasad019
Input to the VGA from RS232(UART) through FPGA
I already have the code to display colours on the screen, i connected xps_bram_controller to bram block, i connected PORT A in Bram block to red_out pin logic and i am giving the input in the hyperterminal Is it Work.........
Historian
Historian
Re: Input to the VGA from RS232(UART) through FPGA
And your question is?
Visitor dprasad019
Is that procedure possible?....
Historian
Historian
Possibly, but it's still not clear what you're really doing.
Advisor joelby
Advisor
It sounds a bit like you want to implement a sort of basic serial dumb terminal.
What's the serial port connected to at the moment? You can't connect a BRAM directly to a UART - you'll need something that does something like this:
- Wait for character to come in to the UART
- Write the value in to BRAM
If xps_bram_controller works using a frame buffer, then the 'write the value into BRAM' step will actually be more like this:
- Look the character up in a ROM font table
- Write out the whole character (e.g. 8x8 bits, depending on the font size) into the the appropriate parts of the BRAM. This might take several write operations to complete.
- Increment your counter so that the next character goes to the next bit of BRAM.
