willie1987
Interface ADC to FPGA
Hi there,
I am rather new about FPGA design. But i'm stuck with this problem.
How to write up vhdl code to interface adc to FPGA ??  Currently, I am using Virtex-4 User FPGA: XC4VSX35-10FF668
Hope someone can assist me ..  (:
Thanks you in advance
eilert
most important is to take a look at the datasheet of the ADC you are going to use.
There you find a description of the ADCs interface, for which you have to design the counterpart in the FPGA.
That's a good starting point.
If you are lucky, it's some kind of standard, and you find many examples for it. Here, or at opencores or other FPGA related sites.
Have a nice synthesis
  Eilert
eilert
  Eilert
willie1987
Thanks for your quick response.
Don't mind if i can send you the file to have a look instead??
eilert
feel free to send me your stuff via private message, if you don't want t o post it.
  Eilert
bassman59
Historian
Historian
Homework assignment?
rago822
hi...i am having problems with the coding for interfacing of adc to fpga..im using a spartan 3e fpga..the ;problem is that the simulation is working as expected but the ouput on the leds are just kkeping on bl;inking...and i am not getting the value that corresponds to the formula...please clarify this for me
thanks a lot
