Visitor sreedna
Kintex 7k325T DDR3 interface
This is the first time, I am using Xilinx devices for my project. I am designing a board with Kintex 7k325T and Micron DDR3 interface.
My questions are here:
1. Is Soft IP or Hard IP (memory controller) is available for DDR3 interface?
2. If I can use MIG interface to my board, is there any Verilog code is still required or directly can I perform read and write operation?
3. What is the procedure to initialize the board (board bring up)?
4. Is there any boot code is required to initialize the FPGA? can I download through Xilinx website?
5. Is there any source code for DDR3 memory interface?
Above all questions are for Zynq X7030 device also...Since I am designing another board with this device too...
Please respond ...
Re: Kintex 7k325T DDR3 interface
Hi @sreedna
Please avoid creating multiple threads for same topic.
https://forums.xilinx.com/t5/7-Series-FPGAs/Kintex-7-DDR3-interface/m-p/739503
Thanks,Vijay
