MCS Vs BIN file
What is the difference between these two file formats (MCS Vs BIN) ? why PROM file formatter (11.5) is not supporting to generate the .bin file (for slave serial mode configuration) ?
Scholar austin
Re: MCS Vs BIN file
s,
http://www.fpga-faq.com/archives/33100.html#33108
Is a good discussion of what is going on.
25 years ago, eeproms were programmed with prom programmers, that had Intel format, Motorola format, and various other formats.  The eeproms made by Intel and Motorola are long gone, and so are the programmers, but the file formats remain, and became defacto standards.
The .mcs, .rbt, and others are ASCII representations (ASCI 1 = 31H, and ASCII 0=30H) with headers, comments, etc.
The .bin, .bit are binary files:  all single bits, 1's and zeros.
All formats have evolved over the years, and are still used.  New companies make programmers, and all the old formats get supported.
So a .bin is used to program the part using an Impact programming cable (JTAG or parallel), and a .rbt is the file readback when doing averify Impact (also provide a .bin readback file which is not equal to the .bin file used to program the part!).
The .mcd might get used to program a prom for the final board, to configure the part upon power on.
Austin Lesea
Principal Engineer
Xilinx San Jose
Tags (2)
Re: MCS Vs BIN file
The MCS file is a HEX file where two ASCII chars are used to represent each byte of data.  And the binary file of course just contains just the raw byte stream, in sequence.
So the MCS file seems less efficient, because it takes 2 bytes to represent 1 byte.  But it has a couple of advantages (1) It has a checksum at the end of each line for integrity.  (2)  Each line includes the address where the line should be located in memory.
So for example, if a MCS file contains a few segments located far apart in address space, it can be small while the equivalent binary file might be huge, because it would have a lot of 0x00 or 0xFFs to fill the space between segments.
You can easily convert a MCS file to a binary file using an old command line utility called HEX2BIN.EXE  You can find on the Keil webste at
   http://www.keil.com/download/docs/7.asp
Jim
Re: MCS Vs BIN file
Thanks for the details.
Observer sndp.swamy
Re: MCS Vs BIN file
what is long form / abbreviation of the file MCS and BIN ?
Teacher eteam00
Re: MCS Vs BIN file
I don't understand this question.  Please rephrase it, or explain your question.
Thank you,
- Bob Elkind
SIGNATURE:
Summary:
Mentor awillen
Mentor
Re: MCS Vs BIN file
I think he's asking what "MCS" and "BIN" are standing for (i.e., what they are acronyms for).
Adrian
Please google your question before asking it.
If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
Teacher eteam00
Re: MCS Vs BIN file
BIN is a contraction of binary, it is not an acronym (in this context, at least).
MCS may or may not be an acronym.  Intel developed the .MCS file format in the 1980s for their lines of MCS development systems (e.g. MCS-80, MCS-86).
- Bob Elkind
SIGNATURE:
Summary:
Historian
Historian
Re: MCS Vs BIN file
- Bob Elkind
MCS isn't an acroynm, it's an initialism.
Mentor awillen
Mentor
Re: MCS Vs BIN file
- Bob Elkind
That's debatable.
Historian
Historian
Re: MCS Vs BIN file
Wow, that Wikipedia article was long and impenetrable.
I was taught that if you pronounce it as a word, like "radar" and "laser," then it's an acronym. If you say each letter ("FBI," "ATM," "LCD"), then it's an initialism.
There are some pathological examples. Is "LED" an initialism or acronym? I always pronounce the three letters and never say it as a word. So it's an initialism. Some people say the word.
Mentor awillen
Mentor
Re: MCS Vs BIN file
Sorry, I should have been more specific:
Although the term acronym is widely used to describe any abbreviation formed from initial letters,   most dictionaries define acronym to mean "a word" in its original sense,     while some include a secondary indication of usage, attributing to acronym the same meaning as that of initialism.
Summary: while you have most reference books on your side, some disagree. Not that it really matters anyway ;-)
Adrian
Newbie jagsmani
Re: MCS Vs BIN file
hi
MCS means Micro Controllrer Series .
BIN means Binary file
inorder to generate the idf file of iMPACTin the PROM File Formatter process we will give these two files as input files
