erez.benari
ML605
Hi all,
I'm designing a board I need to use both HPC and LPC connectors.
Where can I find the mechnical schems so to place the connectors properly?
Erez
eteam00
Professor
Professor
You can find the ML605 board layout Gerber files here.
-- Bob Elkind
SIGNATURE:
Summary:
erez.benari
Thank you so much!
One last question, are the HPC and LPC pins are all differential?
If not, how many pins can be used as single ended?
mcgett
With the exception of the MGT and I2C pins, all of the pins may be used as single ended or differential.
erez.benari
In pages 59 regarding the HPC and 64 regarding the LPC it says only differential configuration is available.
I'm confused...
Please advise me what is true.
THANKS
eteam00
Professor
Professor
In pages 59 regarding the HPC and 64 regarding the LPC it says only differential configuration is available.  I'm confused...
UG534 v1.6, page 59:
The 10 x 40 rows of a FMC HPC connector provides connectivity for:
160 single-ended or 80 differential user-defined signals
UG534 v1.6, page 65
The 10 x 40 rows of a FMC LPC connector provides connectivity for:
• 68 single-ended or 34 differential user defined signals
I do not understand your confusion, might you please explain your uncertainty?  The guidance which Ed (McGett) gave you is correct.
-- Bob Elkind
SIGNATURE:
Summary:
erez.benari
The confusion starts in the lines below the ones you stated which say in pg. 59:
Of the above signal and clock connectivity capability, the ML605 implements the following
subset:
• 78 differential user defined pairs:
• 34 LA pairs
• 24 HA pairs
• 20 HB pairs
• 8 MGTs
and pg. 65:
Of the above signal and clock connectivity capability, the ML605 implements the full set:
• 34 differential user-defined pairs:
• 34 LA pairs
What you described is the FMC HPC and FMC LPC standard yet, as I understand it, ML605 doesn't implement this standard, only partially.
Am I correct?
eteam00
Professor
Professor
Your question is quite reasonable, for someone who is not experienced in FPGA design.
FPGAs afford considerable flexibility in the configuration of their IO pins.   Each pair of IO pins can be separately configured for either differential IOs or for single-ended IO.  Each differential pair can be configured as an input, output, or bidirectional pair.  Pin pairs which are configured (by the designer) as single-ended IOs can be individually configured as any combination of input, output, or bidirectional IOs.
Mcgett's advice still stands.
Does this clear up your remaining confusion?
-- Bob Elkind
SIGNATURE:
Summary:
erez.benari
First of all - lots of thanks to you all for your answers.
It sure helps a lot. yet just to be sure - I can use the ml605 with 156 single ended pins on the HPC con
and 68 single ended pins on the LPC con.
Am I correct?
mcgett
Yes, you can do this.
I am somewhat concerned about your approach to the FMC interface.  The FMC interface is made up of 3 buses, LA, HA and HB.   PCB trace length matching happens within each bus for each FMC connector.  If you are attempting to create a single 224 pin bus you may have timing problems due to skew between busses and between FMC connectors.
erez.benari
Thanks guys.
I will take your words in consideration.
