Matrix Tranpose
Hi to all,
I wrote matrix transpose program in vhdl environment , but i face one problem in that , it process only one data at a time, which is not my requirment , programe should take all entry simulataneously and provide transposed output in same manner , below is my code ...
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use work.typedef.all;
entity Matrix_Transpose is
Port ( A_In : in Doublearray;
trans_signal : in std_logic;
clk : in std_logic;
trans_ack : out std_logic;
transMat: out Doublearray);
end Matrix_Transpose;
architecture behavioral of Matrix_Transpose is
begin
trans_process : process (clk,trans_signal)
begin
if(rising_edge(clk)) then
if (trans_signal='1') then
for i in 0 to 2 loop
for j in 0 to 2 loop
transMat(i,j)<=A_In(j,i);
end loop;
end loop;
trans_ack<='1';
else
trans_ack<='0';
end if;
end if;
end process;
end behavioral;
package work.typedef declares single and double array type....
It worked for me with little changes in your for loop increment, you have declared 4 X4 matrix but assigning only 3 X3.
Aalso the order of for loop making difference.
You can see that outout is available as soon as trans_ack is asserted.
Attached the project along with tb for your reference.
Hope this helps.
Vanitha.
Do you mean one element of A_in is copied to one element of  transMat at a time and the for loops are not incrementing in one clock ?
Can you show your double array declaration, test bench for trans_signal generation, how the input matrix is filled and simulation waveforms ?
Vanitha.
exactly .. it accept only one element at a time
 and here is my double array declaration declared inside mydef package...
library IEEE;
use IEEE.STD_LOGIC_1164.all;
package Typedef is
type DoubleDarray is
array(0 to 3, 0 to 3) of std_logic_vector(7 downto 0);
type SingleDarray is
array(0 to 3) of std_logic_vector(7 downto 0);
end package Typedef;
Hope this helps.
Vanitha.
