Maximum Frequancy
Hey All,
I want to know what is the maximum frequency of xc6slx75 fgg676 -2 ?
you can find detail here
http://www.xilinx.com/products/silicon-devices/fpga/spartan-6.html#productTable
The exact frequency depends upon your target design .
You just need to implement the design with your target constraints . Check the timing report and device utilization
Thanks and Regards
Balkrishan
Hello @ehab,
For which component, you are expecting value of maximum frequency? Is it Digital Frequency Synthesizer (DFS) or Delay-Locked Loop (DLL) or GTP transceiver clock ?
You can check Spartan-6 device datasheet to know maximum operational frequencies of most of these components
http://www.xilinx.com/support/documentation/data_sheets/ds162.pdf
Ashish
Thanks and Regards
Balkrishan
